Pink(ish) Wire to Driver side Headlamp
art74
When I started the headlamp relay upgrade I saw the wires coming from the loom to the driver's headlamp were gray with black trace and pinkish white. I know the gray with trace is the high beam. However, per Chiltons and every wiring diagram I can find online the low beam wire should be gray, not pink. The low beam wire from driver to passenger headlamp is gray, like the diagrams.
Any thoughts why?
I know CJ wiring is not always true to what the factory says, but was just curious.
Any thoughts why?
