Installing a Rough Country 4" lift. It came with a drop pitman arm. Looking to also install a 1 1/2" shackle lift. Would I need a different pitman arm or would the pitman arm that came with the lift be OK?
83 CJ7 350 tbi, TH350, D300 twin sticked & clocked, narrowed Chief D44 Eaton Elocker & Moser shafts, Explorer 8.8 Detroit locker, 410's, RE 4.5" spring lift 1" body lift, 35" Claws, cage tied to frame, Corbeau baja seats, HD tie rod and draglink, u-bolts flipped, custom skid plate and sliders, Warn 9.5ti winch with Amsteel synthetic line
You are much, much, much, much better off doing a one inch body lift than doing a shackle lift. That way, you don't have to worry about the pitman arm. Yes, it is more work, but well worth it.
