Power steering bracket Help
Techlight
- Media
- 1
- California desert
- 1984 CJ7: 4.2l i6 (mild cam), Team Rush, Howell TBI, T5, D300, D30-front, AMC20-rear, 33/10.5/15 BFG A/T's........................
1964 Kaiser CJ5 (sold),
1960 Willy's CJ5 (sold)
Hey all....
I am having trouble with my power steering pump and the top idler pulley not aligning correctly. My belt comes off that ilder pulley and dives in the direction of my firewall. It's squealing pretty bad and I can't figure it out. I replaced the original pump because I thought it was bad. At first it was fine, but now I'm having the same issue. I'm sure it's possible that the pully on the pump is overpressesd for my set up but I wanted to confirm the brackets before I went that route. Also, I'm buying used pumps with pulleys attached so I'm not sure if they are overpressed or not.
See pic for this part: I was told that my top idler pulley (#1 in photo) was out a bit too much and that the skinny plate and the L bracket (#2 in the photo) need to be installed in the reverse order. So basically I was told the L bracket might need to go on first and then the skinny plate and not the opposite (which is how it is now).
I can't remember how it was when I took it off and my mechanic couldn't say for sure. I can post a picture of the angle of the pump if need be.
Can anyone confirm the correct placement of these brackets please?
Thanks in advance.
Thanks in advance.
