power steering conversion
Hi Joe! welcome to the site. I did indeed just finish the same conversion on my 78 / AMC 258 i6 / 4.2l -6, If you need any help just let me know. There were actually a couple things iI learned the hard way.
Where did you source your parts?
List the parts you needed to go from manual to power?
Brock, I'm still gathering info but I found two possable donars on Craiglist. One is a Grand cherokee, the other is a YJ. If you are in Clovis, check Tex. around Houston or along the Gulf coast. Jeeps die early sometimes with the salty climate. Let me know how you are coming along.
Joe
I'm pretty sure just about any saginaw box fits. I got my old one off of a 75 Chevy mid size car. Don't remember which one exactly. The ratio may be a little weird and the hoses may require an o-ring or a flare... But I believe all the boxes use the same bolt pattern.Did you find a list of what box's will fit the CJ?
If I'm way off base here, someone please correct me...
wagoneers huh, there are a few near me, I'll take a look and report back.
I wonder if I can use the entire system?
For the return line not the pressure line , can I just use a length of hose to rplace my dry rotted one or must I order the whole deal?
