Power Wagon Axles for sale
- Featured
- 3
- Media
- 881
- Resources
- 193
- Solutions
- 50
- Central FL
Did you ever want to build a diesel powered Jeep on late model power wagon axles but didn't know where to get the axles?
Well sleep better good readers, because Mopar is offering up a great line of aftermarket axles INCLUDING the big AAM 9.25-inch front and 10.5-inch rear axles with selectable locking differentials from the current Power Wagon truck.
check out this press release we recently received from Mopar, including part numbers so you can get them at your local Chrysler, Dodge, or Jeep dealership.
Axle Assemblies now available exclusively from Mopar®
The Jeep® Wrangler Rubicon front and rear axle assemblies will provide the next level of off-road performance for your CJ, YJ or TJ. These axles are shipped with current Wrangler Rubicon suspension mounting brackets installed. Adaptation of these units into previous models is the responsibility of the purchaser. These axles come completely assembled with 4.10 gear, disc brakes and locking differential. A Limited slip rear axle assembly is also available.
o P5155252 Axle, Front Assembly, Dana 44 , 2007-09 Jeep Wrangler, 4.10 Locking Differential, Without Brakes
o P5155256 Axle, Front Assembly, Dana 44 , JK, Modified For TJ
o P5155084 Axle, Front Assembly, *** Dana 44 , 5 on 5.5 Hub, with Open Differential
o P5155087AB Axle, Front Assembly, Stock Power Wagon, 4.56 Ratio, With Locker
o P5153826AB Axle, Rear Assembly, 2007-09 Jeep Wrangler Rubicon, 4.10 Ratio, Locking Differential
o 1 P5155257 Axle, Rear Assembly, Dana 44 , JK, Modified For TJ
o P5155260 Axle, Rear Assembly, Dana 60, *** 4.10 Limited Slip, 5 x 5.50" and 5 x 5.0" Bolt Pattern, Modified For JK
o P5155083 Axle, Rear Assembly, *** Dana 60, 5 on 5.5 Hub, Limited Slip Differential, Leaf Spring
o P5155088AB Axle, Rear Assembly, Stock Power Wagon, 4.56 Ratio, With Locker
Read More | Digg It | Add to del.icio.us
More...
More...
