Build Thread Project Rot
JAE
- Austin, tx
- 77 CJ7 with304/th400/ q-trac. READ 4.5 lift and lots of rust
So this past Memorial Day I convinced my wife that we needed an open top Jeep and I was lucky enough that she actually agreed on the condition that it be drivable since we already have 3 other full blown projects. We find one and go check it out. It looks rough but starts up and sounds decent but I wasn't able to do a good look over on it because of the weather conditions. Well after a 120 mile drive home in the thing in holiday traffic the weather had cleared up. I start looking over it closer and find that all the body mounts are destroyed, where most of the body mounts attach to the tub are crushed, one area is being held up by a piece of 2x4, the floor of the tub next to the drivers seat is not attached to the side of the tub anymore and that there's some decent holes rusted through the rear section of the frame. I then realize that what was supposed to be our new summer toy was now another project (#4), and that I was probably lucky that it didn't crumble out from under me on the drive home, oops.
On to the details. It's a 77CJ7 with the AMC 304 / GM Turbo 400 / QuadraTrac / 20 rear/ 30 front. A p.o. had installed a Rubicon Express 4.5" lift and 35" tires at some point that were somehow in decent shape. The lift and the tires are probably the only good parts on the thing.
The plan. I was trying to decide between if I wanted to patch my frame or just build a new one but I found a good deal on a decent used one so I'm going to pick that up and do some upgrades on it then swap stuff over. Unfortunately my t case doesn't have the low range option so I have to swap it, deciding between a np241 and a Dana 300 . Im leaning towards the 300. New t- case means new axles. Luckily I already have a 9" and matching Dana 44 already built but have sat for a while and need to be freshened up. As for the body I'm just going to buy a sheet of steel and start making patch panels.
It sounds so simple when I put it together like that, if only it was. I've never done a build thread before so hopefully it will help keep me on track and get this done. Especially since I told the wife I'd have it drivable again by next Memorial Day and I really just started working on it. And I know, it needs pics. I'll add some when I figure out how since I have to do this on my phone.
