Proper connection of hoses for heater
Rdavison39
Oakville Ontario
1977 CJ7. 304 H. 52,000 original miles.
2010 Wrangler 2Dr
Be aware, the hose connection on the water pump is not the same size as the heater core connection. I think it is poor engineering. The stock hose is larger on one end than it is on the other. You can get around this problem by getting an inline reducer. Bigger hose goes in, smaller hose goes out. It seems a little rub gilberg, but will save a bunch of hassle in the long run.
Glad to find this information about the 5/8 x 3/4 hose size on the forum in multiple threads. I discovered my heater hose from the water pump was leaking and have ordered the ACDelco (GM) molded hose (thanks for the info Jon) from Amazon along with a Gates 5/8 straight heater hose. Mine sprung a pinhole leak right where it had been rubbing for some time on the top of the alternator. I think the molded hose with the 90 degree bend will avoid that in the future.
Can anyone tell me... Do I need to drain the cooling system to install the heater hoses? I was thinking I could probably just remove and replace one hose at a time with minimal fluid loss. Any suggestions on heater hose replacement would be appreciated. Thanks
Can anyone tell me... Do I need to drain the cooling system to install the heater hoses? I was thinking I could probably just remove and replace one hose at a time with minimal fluid loss. Any suggestions on heater hose replacement would be appreciated. Thanks[/QUOTE]
No. You loose very little
With that thing not being hooked up for so long, I'd wonder:
1. Is there was a reason it was bypassed? Maybe a leak.
2. Could it be full of :dung: at this point and do I want that surging through my motor?
I think I'd remove the heater core and have it checked out before connecting it to the motor.
Be advised... I'm just a novice at this.
This is a real good point.
I think the last reply on this thread was intended for a different post.
Thanks for he feedback Belizean! Glad to hear I don't have to drain the system to replace the heater hoses.
This is what happens when you hi-jack a old post.
Actually I think the poster could be correct. That is probably why it is disconnected. The last owner could of decided the heater core was shot and just didn't want to fix. Its a medium job to replace. Replace mine for the first time probably 4-5 years ago. Good luck
Thanks for posting the update. I know Gates makes a similar hose, but it's straight. Got mine from Rock Auto. And yes, it's a dumb design.
$20.00
  10.0%
