Steering Pwr Steering conversion and YJ pitman arm
Weezykid
Currently converting a manual steering 1984 CJ7 SVP to power steering. Currently has YJ OME spring lift, SUA. Have seen conflicting info on the YJ pitarm arm usage. Some say it is interchangeable with the CJ7 arm, but seeing other post say it is not clocked correctly and needs to be filed.
Which is true? Running a Lares 11430 rock crawler steering box 32mm output.
