Question about 258 Aluminum Intake Manifolds
Rescue Diver
Full Time Jeeper
Kansas City
1979 CJ-7 with a fiberglass body and 1982 wide track axles, 258 I-6 with a 1995 4.0 head, HEI distributor, Motorcraft 2100 Carb, T-18 wide ratio tranny, Super Lift Springs and 33s, a 1997 BMW 328i, and a 2010 REDLINE CONQUEST TEAM Cyclocross Bike. :)
Can someone please tell me what the point of heating the intake manifold with coolant through the heater hoses is? I understand that the older cast iron intakes got heat from being bolted to the exhaust manifold, but why heat them at all? It seems to me that this would make vapor lock more likely on hot days. Is it some kind of emisions thing?
I just did a quick search and may have found my own answer. I take it that heat sink thing that bolts into the bottom of the intake under the carb is an electric heater to heat the fuel/air charge on its way to the engine when it's cold. And I also read that there's a heat switch on the manifold, so I take it that the switch shuts off the power to the electric heater once the engine warms up. That would all make sense. Has anyone run with and without this to see if it really makes much difference? I'm hooking up a manual choke, so I think I'll be fine without having all this extra :dung:(heater hoses and wires to the intake), but would like to get opinions on it.
the water hoses are still on mine, but the heater on the bottom hasn't been hooked up for two years. its cold natured but, most carbureted vehicles are. outside that it runs fine without it.
Thanks for the info. I wonder if it's even neccessary to have the heater hose routed through the intake without using the electric heater? I like the nice simple look of just having the two hoses run from the front of the engine, down the passenger fender to the heater core. I'd rather not change that unless someone can give me a good reason why I should heat the manifold. I noticed that the clifford after market manifold is also water heated.
IMHO the AMC 258 i6 / 4.2l is incredably cold natured, any thing I could do to get it warm as fast as possible would be a priority with me. this includs the TAC and cook stove on the exhaust manifold. I noticed the difference when the 4.0 head required headers and the TAC went away.
Suit your self, I like to think that the engineer that designed it had to have a good reason to change from the solid cast iron manifold to the wet aluminum. :D
I've had ice accumulate in the carb before. My vehicle kept getting slower and slower until I had to pull off the road. Idling for a few minutes melted the ice and I was able to go on. It seems like it always happened when it was snowing out. One reason to heat the intake is to prevent this.
but his isn't one of them.:D
If you're talking about me, after this weekend, I'll be running a 1995 4.0 H.O. head with a 1995 tubular exhaust manifold, and an 80's aluminum intake manifold that has the water jacket. I'm retiring the original 79 head, 1 bbl Carter YF carb, and manifolds. That's why I asked the question. :)
What carburetor did you decide on??:cool:
If you're talking about me, after this weekend, I'll be running a 1995 4.0 H.O. head with a 1995 tubular exhaust manifold, and an 80's aluminum manifold that has the water jacket. I'm retiring the original 79 head, 1 bbl Carter YF carb, and manifolds. That's why I asked the question. :)
I wasn't the one trying to figure out what carb I wanted. I knew as soon as I decided to do this head upgrade that I would be running a Motorcraft 2150 of 2100. Tonight I just rebuilt an old school 2100 with 1.14 venturies. I have to wait a day or two for my new jets to arrive in the mail before I can screw down the air horn.
I agree about not running antifreeze through the manifold, im working on getting my 79 CJ7 running and plan on not running it through. The only drawbach i find is no good place for an after market temp gauge. That and the potential to warp the intake.
Its kinda a thermo dynamics type of issue and view. If you heat the intake to apporx 195F Thermostate, the fuel / volital gas will evaporate, flash off, and STAYS in atomization. With out heated intake the fuel would pluddle, thus hard starts and issues in general. The unheated jacket is cool to touch when the fuel first start to evaporated. Evaporation is a cooling process.
There are TWO heaters the WATER Jacket and the electric porcupine heater under the carb. Both are very important. There are also issues with the radiator hoses and that some of the molded jeep hoses are not avail any more. The entrance & exit intake manifold radiator hoses have a BIG ISSUE if the LOOPS are two high the air bubble will slow the water flow.
Poor heat for vehicle
Lower heat for the manifold if there are air pockets
Hot summer temps may not have enough cooling.... The intake and heater core and even the rubber hoses themselves are all heat disapation devices.
The Cast Iron Manifold are bolted together and that does Transmission heat. There is also a trap door for hot air directions in the exhaust manifold with a BiMetal spring that opens and closes the flapper with them of manifold.
So if you follow the sorry long story .... the coolant, engine temps, hoses,
water jackets, electric heater all work together... if they have faults or issues. Auto will not run well.
I agree about not running antifreeze through the manifold, im working on getting my 79 cj7 running and plan on not running it through. The only drawbach i find is no good place for an after market temp gauge. That and the potential to warp the intake.
I'm actually now planning to run the heater hose through the intake, and I might hook up the electric heater to a toggle switch for cold weather starts.
You have two places in the engine block behind/under the exhaust manifold that would work well for an aftermarket mechanical temp gauge. But that all depends on if you're still using them for their original purpose or not.
$35.00
  17.5%
