OK, I'm taking my 82 CJ7 all the way down and was thinking of having the frame sand blasted and paint it with POR 15, but I've heard someone say the front of frame with direct sunlight the POR 15 will deteriorate. Has anyone used POR 15 and had bad experiences? Is using POR 15 a good idea?
I've used POR15 on stuff for many years. If you follow the directions properly, it's a great product. UV exposure is a problem, so you just need to coat it with something else. I've coated it with POR topcoat and rustoleum rattle can without issues. The directions for POR15 say to apply your topcoat while there is still "finger drag" on the POR15...if you wait too long, you'll just have to scuff it up for anything to stick because it comes out smooth and shiny.
I recommend topcoating anything that will be exposed to direct sunlight. If you have the frame off already, you might as well just topcoat the whole thing, or it'll have 2 different finishes on it. Like I said, the POR15 is very shiny and would look weird if you only topcoat part of the frame.
I've used por 15 for years it will deteriorate in the sun if you don't top coat it. Second it's designed to go over rust. If ur going through the hassle and cost of sand blasting just epoxy the frame you will have a much better product in the end and it will hold up and be ready for anything you want to put over it. Rather that be paint under coating (not recommend) or simply leaving it in epoxy.
67 cj5,225 Dauntless, D30,chrome molies, detroit, D44, full floating detroit, custom steering, disc all the way around,2 inch lift on 31s, armored up
70 cj6 4 inch lift
Check out Mastercoat out of New Jersey. I used their two product chassis coat and was very pleased. Very durable and reasonably priced compared to POR and other epoxies. Their sales support was great too.
Be advised that POR15 is a urethane paint similar to Imron, chemically very different from polyurethane, and is hideously toxic; it should never be sprayed without a full-up respirator. My mind boggles that it's even legal to sell it to unsuspecting consumers.
