Question for those with experience.
Recoil
Texas
1982 Jeep CJ7, 258ci I-6, T176 4sp, Dana 300 Transfer.
OK, I'm taking my 82 CJ7 all the way down and was thinking of having the frame sand blasted and paint it with POR 15, but I've heard someone say the front of frame with direct sunlight the POR 15 will deteriorate. Has anyone used POR 15 and had bad experiences? Is using POR 15 a good idea?
I've used POR15 on stuff for many years. If you follow the directions properly, it's a great product. UV exposure is a problem, so you just need to coat it with something else. I've coated it with POR topcoat and rustoleum rattle can without issues. The directions for POR15 say to apply your topcoat while there is still "finger drag" on the POR15...if you wait too long, you'll just have to scuff it up for anything to stick because it comes out smooth and shiny.
I recommend topcoating anything that will be exposed to direct sunlight. If you have the frame off already, you might as well just topcoat the whole thing, or it'll have 2 different finishes on it. Like I said, the POR15 is very shiny and would look weird if you only topcoat part of the frame.
I've used por 15 for years it will deteriorate in the sun if you don't top coat it. Second it's designed to go over rust. If ur going through the hassle and cost of sand blasting just epoxy the frame you will have a much better product in the end and it will hold up and be ready for anything you want to put over it. Rather that be paint under coating (not recommend) or simply leaving it in epoxy.
Sent from my E6810 using Tapatalk
depending on the amount of deterioration done you may consider just getting a YJ frame
A YJ frame is a lot different than a CJ frame.
Here's the frame I'm working on now. Getting ready to epoxy it this morning I'll post some pics with it in epoxy. I use PPG dp90 a5a090efa588c94fb398552dedec4460.webp 0bb4b40487b860c58bfa4dcdfe994538.webp 6b4f3ec52f41e3d7adb61e2ec7a0f85e.webp b2ae84bd77d2439ddd3062b688d8ea60.webp cdbb55691b18a81308860a9c4660ebe4.webp
Now in black PPG dp90 epoxy. aa023d981aaeec761765c272ac72d1d6.webp ced3ed03262a22deb5b49dc505754fab.webp 0ae136ae5e665bd1315519d8ce71f45d.webp e8ca4eeb0907268ed769536f0f06f8ea.webp
Check out Mastercoat out of New Jersey. I used their two product chassis coat and was very pleased. Very durable and reasonably priced compared to POR and other epoxies. Their sales support was great too.
I've also used Eastwood chaisis black and it had decent results
Be advised that POR15 is a urethane paint similar to Imron, chemically very different from polyurethane, and is hideously toxic; it should never be sprayed without a full-up respirator. My mind boggles that it's even legal to sell it to unsuspecting consumers.
