Rear Drum Brakes Missing Parts
LIVELY5R
- Texas
- 1980 CJ-7with 258, SR4 4 speed transmission, stock everything that I can tell.
I have a 1980 CJ5 with front disk brakes & rear drum brakes. The front seem to be ok. I figured the rear drums would be shot since the emergency brake doesn't work & it didn't feel like the rear were working (everything on this bad boy needs replacing). I opened up the rear drums & saw I had a bad axle seal leaking into it but the pads were not worn at all. I adjusted them and compared it to the Chilton manual and saw the PO had lost the brake adjuster cable, guide, and brake adjuster lever. I adjusted the brakes by hand to where the axle would rotate barely & once I drove it, the brakes seem much better.
However, does anyone know where to buy the three listed parts? The brake adjuster cable, the guide and the lever?
