rear wheel disk brakes rotors and calipers
IOPort51
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
I have the desire to put discs on the Dana 44 I am about to build for the CJ5 .
Here is the the issue.
I think it would be a good thing if the rotors were all the same, as in like the ones already on the front. these are 11 1/2 inch diameter and 1 1/8 inch thick.
What is needed is calipers with E-brakes that will fit the 1 1/8 inch rotor.
You mite think this information was easily available but so far I have found no specs on calipers and very little on rotors.
Can anybody offer information or advice??
It seems the most popular caliper is a GM found on the back end of an 85 Eldorado's. these are 1 inch.
If I could find a list of rear wheel disc calipers from late model trucks and/or cars and there range of operation it would be great.
