Rear Wheel Wobble
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
Yes it's supposed to be spelled "Wobble".
Usual specs. '75 CJ5 - 44 rear end. I plead complete ignorance here. I've done a lot of jeep and other vehicle stuff, but when it comes to rear drive train I'm a complete no-nothing. So, I needed to see my rear wheels spin on my Jeep project. So I jacked her up put blocks all around on the front wheels, and dropped her down on a set of jack stands. At first I scared myself half to death. The Jeep made some VERY bad sounds when it started in gear. When I shut her down the engine kept turning over. The starter solenoid was stuck (need a new one now). Then the starter acted up by not engaging, probably need one of those too. But when she did start the horrible noise was gone. Then I stared watching the wheels spin, well actually wobble. The wheels are brand new so they aren't bent, the tires are also new and balanced properly. The wobble is definitely coming from the axle hub. Both sides wobble, but the drivers side is much worse than the passenger side. Your thoughts are welcome. Am I looking at things all wrong, can bent axles be straightened. I admit total ignorance here.
