For sale Rebuilt Warn 8274 with Barnes 4wd Winch Plate
$2,000.00
2000 available
Details
I have one rebuilt 12v Warn 8274 Winch that has been completely disassembled, cleaned and examined for wear and breakage. Any worn out or missing components have been replaced with new components.
New Components consist of the following:
Warn 9.5 XP motor-
Built for rugged performance and durability this 6HP motor increases the puling capacity to 10,000 lb. (up from 8,000 lbs.)—ideal for today’s larger, heavier vehicles
Gigglepin Billet Brake Pawl kit-
Gigglepin Billet Brake Assembly
-This billet hardened steel has more increased material strength and with its teeth being reduced to 15 teeth instead of 18 it reduces the risk of pawl semi engaging, which could cause damage. Plus, the inner and outer discs provide more positive engagement.
Gigglepin Manual Clutch Assembly with fill plug-
Warn Splined Cam Gear-
Bus Bar Set-
Gigglepin:
* Seal Kit
*Bronze Bushing
*Top Housing Bushing Kit
*Motor Armature Bearing
*Needle Roller Bearing
*Main Shaft C-Clip
*Winch Oil
*Winch Motor Gasket
*12v Pro 100 Albright Solenoid
Wireless Remote Control with 2 remotes-
3/8”X100” Synthetic Winch Rope with Rubber Stopper
- Has a tensile strength of 26,500 lbs, UHMWPE material with 5’ of protective sleeving, rust proof, water proof and resistant to UV rays and a steel. Forged hook.
Barnes 4WD Dual Pull Winch Plate with Roller Fairlead-
This winch also comes with the wired remote controller-It has been wired up and ready to connect to the solenoid located in the solenoid box, for a peace of mind back up.
Winch Part #8631
Serial #94581
F08
Note: Warn tells me it was produced in 1978 with this serial number.
Contact Steve
407-615-0005 (Text)
mopar440cu@yahoo.com
located in Sumterville, Fl 33585
Willing to ship on buyers expense
