    To dismiss this notice
    click the top right X.
Build Thread Renegade restoration
Presvjetli
Ruma Serbia Europe
Willys Overland SW '56 and '58.
Dodge Power Wagon W100 '61.
CJ7 82.
GAZ 69 '56.Grand Cherokee 5.2 '97 ,Grand Cherokee Boston edition '95. ,VW T 25 syncro 4x4
Now it is time to renew my CJ. It's CJ7 82. with 225 ,rear AMC20 ,front Dana 30 ,T-5 and Dana 300 .He came to me from Swiss and...it's little rusty :D
and some more pcs.
This will be hard work because I live in Serbia and it is difficult to find parts for the Jeep,but...I will not give up :)
Great looking CJ,.. that is not that "rusty" we have seen far worse. All Jeeps had a problem rusting before they should have. You can find any part for that jeep you need, you just need to find a USA seller that will ship to Europe.
Good luck with the renew, keep us posted with your progress !
Morris 4x4 center ships world wide.
Thats not a bad looking jeep. I have friends in Serbia its a small world.
:):chug:
Sandblasting for 2 days :rolleyes:
You are very fortunate to own a CJ, esp. living in Serbia!
CONGRATULATIONS!
Best of Luck with your restoration!
Work continues...
Somebody was working before me...but its done bad.I have to do all over again.On first pct. is my helper,Bagy :)
...and more pcs...
Today I lift spring over diff. :)
and few pcs more
Very nice!:beer:
Should I change angle of differentials? When I lift spring over diff I left same angle...
3 degrees is maximum for a single u-joint, 1.5 degrees is optimum. Ive not done an SOA, but you can measure it yourself and answer your own question. When you get past 3 degrees, you will get a vibration and premature failure of the joint.
The common solution is a double carndon joint, some call it a "CV" joint, but its not the same as you would find in a front wheel drive car.
Work continues...
In rust we trust :notworthy:
