Replace captive nut
Replace captive nut
Davezilla
Central Mississippi
74 CJ5 Dirt Drag Jeep
I just broke loose a captive nut in one of my bucket seats. Has anyone ever replaced one? If so, what did you do? I really do not want to buy new seats for my Jeep.
Thanks for any help you can provide.
I assume you mean a nut up inside the seat at the bottom of the seat frame? Just a guess but if so one option is to pull the cover off the seat and re-weld it. Otherwise, if the bottom frame is a “tube” material and not solid stock maybe get a course thread bolt or lag with a shaft size close to the hole then force “screw” the bolt in. If there is enough bite in the metal of the tube it just might work. If the frame is solid maybe you can tap it for a bolt. (Or am I completely off the mark here)
In the bottom of my seat there is 4 nuts that appear to be welded to flat washers that are made into the seat bottom. This is where you bolt the sliders to the seat bottoms. Taking off the sliders, one of the nuts broke loose inside the seat bottom. Someone has suggested getting some Plusnuts and using them. I ordered some of these off Ebay and should have them by the middle of next. I will let everyone know how this works out.
Thanks for your help.
I had one break loose along with the part of the bottom of the seat it was welded to , I took some of the seat cover loose and was able to use wet towels to get under it and weld back into place and it worked great , if your careful it can be repaired as good as new
