Build Thread Reviving "The Bruise" thread
kj 7
Missouri
"The Bruise" 85 cj7 258-D300-stock axles
Nice tread! Looking forward to watching this one! :chug:
x2, I also own a 85 and am looking forward to seeing how you progress through the rebuild
i would just rebuild the motorcraft carb. there is good info on this site if you do a search on it. the guys on here were really helpful when i did mine.
I believe you are correct, if the 5 is new enough to have a 20 it should also have a 30. But check it out to be sure you never know what someone is selling.
Still waiting on dad to bring down the CJ5 chassis so i've been doing some little things:
Applying PB blaster to the spring bolts, shackles and rollbar bolts
Removed the windshield. Only had to drill out 1 bolt from the hinge.
Sanded the entire front face of the windshield to inspect and remove rust. It took a good 2.5 to 3 hours with 80 grit. Looks really good so far. Today, I taste metal :eek:!
I'm only going to paint the outside of the windshield frame as the inside is still original and looks good. I might paint the outside blue like the rest of the jeep or black. Think I'll mock up the look of it in photoshop.
Yep, pulled the cover today to reveal 3.54 gearing. 39 on ring gear 11 on pinion.
span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
Got the roll bar off this weekend. What a task! I broke 2 T45 torx sockets, had to drill out 1 bolt and grind the head off the other.
I've been strippin' down the tub (the rear end can wait, it ain't goin' anywhere :)) because all I see is major rust at every pinch weld and everywhere else. I don't care about surface rust but when I can push a screw driver through 2/3's of the welded seams, something has to be done.
hey bud, you have a axle housing from an AMC20 with no carrier, axles and or anything else of value in it do you not??
Do you have plans for it??
If it is straight, has a centered pumpkin and is a narrow track I would like to discuss this further.
We can talk here or send me a PM.:cool:
Haven't got anything done with the jeep this week.
Been dealing with a horrible toothache and the taste of metal from grinding & cutting dust doesn't help.:( My whole jaw is in pain so i've had to stay doped up for days until I can get to the dentist. Sux!
Thanks. Finally will get to the dentist tomorrow. After Christmas weekend, gonna start hittin' it hard. I'm gettin' a few more tools for christmas so can't wait to try them out.
Found a 2.5 inch Daystar lift kit still in box for my KJ for only $130! But the wife won't let me:mad: (same old story). She says either get my teeth fixed or the lift kit. Tough choice...:laugh:
Make up your mind yet? :laugh: Soon we'll all have this great healthcare plan. Id get the lift. :rolleyes:
$100.00
  50.0%
