Build Thread Reviving "The Bruise" thread
kj 7
This thread is my documentation of reviving my 85 CJ7 that's been sitting in the driveway for the last 4 years. I was in college when the rear end went out, disconected the drive shaft and drove around "1 front wheel drive" drive
. When my wife and I bought our house, I quit driving it and bought a Liberty (which I really enjoy, don't knock it or I'll know you read too much JP magizine!) I recently got sick and tired of looking at the de-commissioned jeep in the driveway so last weekend it took over the Liberty's comfy garage spot & won't be leaving unless it's under it's own power.
The upgrades on it so far are as follows:
Previous owner:
Shackle reversal lift (I think??
In College:
Installed 1 piece axles in AMC20
Fabricated locking cargo boxes onto fender wells
Fabricated front sway bar disconnects
Fabricated roll bar to windshield frame CB rack
Repainted hood, doors, and front fenders
Did a "Nutter By Pass" (i think??
Installed a mc2100 improperly but it still ran better than the Carter bbd
TFI ignition
Installed cd player
Flat fender cut
Upgraded to 33" retread tires
Down graded to 31" retread tires
Last year:
Removed grill, killed the rust and repainted
Current things that need fixed to get it on the road by next summer:
1. (the only thing that worries me) Replace Ring & Pinion in the amc 20. If I end up going with a better gear ratio, doing the same to the Dana 30 . I will be setting up the gears myself, so it should be interesting...
2. Cut out and patch major rust where the frame/rollbars/body meet. I don't care if it looks great but has to be SAFE!
3. Get a different mc2100 or rebuild kit and go through it.
4. Replace the driver side brake line on amc 20. I twisted it off tonight while removing the brake cylinder.
grill before:
grill after:
Current reverse light switch. Gotta fix that:
Like I said, the structural rust has to be dealt with:
Inspecting the rear end. Roller bearings, Yum!
How it sits now:
I'm going this weekend to check out some narrow track CJ5 axles. If they're good, I'm gonna swap the ring and pinions (assuming they have a lower? gear ratio).
span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
! 110 you'll feel it but feeling 220 is probably the end
