roaring amc 20
roaring amc 20
drain the oil out and if you see any debris than you'll know that the pinion has worn into the ring gear, which could cause the noise. Could be a bearing, could plenty of other things. If you see debris, pull the ring gear off and have a shop magnaflux the ring a pinion. If they don't see any big cracks then put it back in. You'll be able to check the bearings while it's out as well.
