Round Two: Rough idle, runs like garbage ::SOLVED::
Redcolt88
Central California
1984 CJ7, 258 w/ tbi, T176, Dana 300 w/ 4:1, D30, AMC20, 2.5" lift springs, open diffs, 33x12.50r15s,
Glad to hear you got it fixed, you could also run a compression test to see if any damage was done to the valve.
very interesting indeed. I would wonder if there was a defect in the plug, I would not think the low compression factory motor could create that much pressure, but stranger things have surely happened. congrats on getting her running right.
That's not a bad idea. Hopefully I will have time this week after work to do it, next weekend my dad's jeep is getting all the love. he bought a clean TJ and just ordered his 2 inch lift, wheels and tires, and a LOD rear bumper. A lot to do for a weekend :)
Good point, I still have the old plugs. I could see if any of the other ones are weak. If the original theory is correct then it would stand to reason maybe some of the other plugs where damaged. I'll do that when i do the compression test.
Yeah, like look at where it broke. It could have even melted off due to the heat or just broken.
Hey Redcolt, sounds like we live in the same area. I'm in Bakersfield how bout you?
I have seen this before from a 'backfire' and then rough/no idle.
I would suggest a compression test now with an eye on cyl #5.
What brand of plugs are they?
They are Autolite coppers p/n: 985
I replaced them with the same plugs. I work with a guy who used to work at NAPA. He won a trip to tour a bunch of factories and one them was where auto lite plugs where made, they are actually owned by Honeywell. I was a die hard NGK guy but he convinced me that Autolite is the way to go and I've always had good luck with them. This is the first time I've ever heard of a legit failure from an auto lite plug. If this new set gives me any trouble I will have to start looking at different brands but right now the jeep runs like a top.
$35.00
  17.5%
