Second rear shock mount?
That would explain the rough ride.
I was looking at new leafs but have no idea which to get (how many leafs). I have a fiberglass tub and a hard top, otherwise I believe it's mostly stock. I will measure the distance between the leaf mounts today to see how it compares to others.
Finally got it measured, I get 42.5". Wonder if po put them on backwards? The right side rear mount is a bit different, only had mounting flange rear of the mount, nothing on the front. Anyone know if I could just unbolt and flip them? Are the nuts in the frame welded or would I have to cut off the rear cross member to get to nuts?I would suggest packing a tape measure and camera to compare with other CJs that you would see in your area. Comparing to my CJ, I get 44.5" from the spring pivot hole to the top spring shackle hole. The spring shackle does seem to be mounted a bit forward from what I see. Thanks for sending in that picture, something is not right somewhere.
Finally got it measured, I get 42.5". Wonder if po put them on backwards? The right side rear mount is a bit different, only had mounting flange rear of the mount, nothing on the front. Anyone know if I could just unbolt and flip them? Are the nuts in the frame welded or would I have to cut off the rear cross member to get to nuts?![]()
