Setting Up To Make Custom Wiring Harnesses...
TeamRush
Featured
So.West Indiana
'72 CJ
Though I'd give up on the ':dung:' on the intenet, one size fits NOTHING stuff, and try to do a custom harness when I fixed my 'Issues' in the '73 first, the '79 later...
These are my thoughts, offer up any alternative theories or ideas...
1.There has been 40 years of connector evoloution since AMC cranked out the base wiring harness for these Jeeps, and the 'Replacmets' not only don't fit, but are just as INADIQUATE as the factory harnesses were.
2. MODULAR HARNESS!
Newer cars have them, break a connection, plug in the HID headlight harness with relays already installed,
Break the harness and plug in the Trailer wiring without having to run around and do stupid things,
Tracking wiring, splicing into wiring, never getting it to seal back up, ect.
3. Dedicated grounds, 'Weather Pack' water/crud/salt proof connectors,
Self protected wiring bundles, no more of that loose wire :dung: with a 25-40 year old wiring loom decaying around it...
4. A fuse block that actually gets enough current out to the accessories to work properly and has enough circuits to supply about everything on it's own fuse or breaker.
5. Circuit breakers for the stuff you can't afford to go down on you...
6. No more 16 & 18 Ga. wiring to high current load devices.
Everything bumps up at least two wires sizes, with the exception of dash lights and low voltage sensors...
7. Terminals for factory lights that are actually on the wires, no more having to cut and strip, use a cheap terminal to crimp on an under size wire to begin with, ect.
There is nothing I can do about the connectors that Jeep used in some places, the park lights and tail lights for instance,
But the harness should have PRE-TERMINATED wiring with replaceable sections when they turn to :dung:...
8. I've ordered in about 16 colors of 18 and 16 Ga. wire for dash lights, gauges, ect.
I've got 10 colors of 10 & 12 Ga. wire already here,
And I've ordered about 2,500 of the CORRECT terminals to revamp that bulkhead connector and most of the 'Packard' terminals used in the Jeep.
9. I've found a headlight switch and connector that directly replaces the factory connector, so you can use your Jeep bezels on the lights, instead of a generic 'Nut' on the dash...
There is no reason the harness shouldn't FIT the vehicle, especially that under dash wiring tangle that is a nightmare for so many people...
10. Conversion harnesses...
There is no reason in the world you should be able to order in an HID (H-4) headlight harness that plugs directly into the vehicle harness...
Same with trailer lights.
Same with a GM steering column since the Jeep columns are getting scarce, and there are MILLIONS of GM columns out there just begging to be transplanted! A short adapter pigtail is all that should be required instead of having to rewire the entire under dash...
11. Gauge cluster with the CORRECT electrical electrical terminals...
The basket case in my Jeep from previous owners (POs) is what prompted me to start this, and it got COMPLETELY out of hand!
No reason why a 'Standard' harness with year specific gauge cluster pig tails and PERMANENT water/corrosion proof connectors shouldn't be available...
12. SEALED, WATER PROOF RELAYS are all over the place in GM vehicles, and we are still dealing with '60-'70s relays that get corrosion issues like crazy...
You will be able to buy them off the shelf at ANY auto parts store when you need replacements...
Same with tail light connectors, no reason why we can't have a 'Chevy' type connector in the rear for the tail light harness so you can plug in one of a 100 different makes of trailer wiring harnesses...
My .2
Whoever put the fuse block under the dash should be shot with a dull bullet.:shooter:Put it some place you can see it and service it.
I looked at several "Salvage" power center/fuze/relay blocks and found nothing acceptable. the wiring was all too small and even though the connectors could be removed I never found replacements that could be re wired. Have you found a suitable power distribution center?
The other issue is documentation, A good wiring diagram with color codes is a joy forever. The closer to the original the better. I do not want to be remembered as the dumb @^$*^& PO who butchered the wiring. I am very impressed with the 11X17 laminated color diagrams.
So those are my two biggest points with any custom wiring harness, access and documentation.
Please tell me more about your water resistant relays.:cool:
It won't be as hard as you think. Wiring is not that bad. You will appreciate it more when you are done. If you do have a problem you will know exactly where to check for it. Good job!
"TeamRush is junk yard genius and its his web site...."
http://www.jeep-cj.com/forums/f49/setting-up-make-custom-wiring-harnesses-13311/#ixzz1pIZUnExY
I am aware of this.:D
I looked at the NEMA boxes and did not find the dimension I was looking for not deep enough for the relay wiring. This will more than likely become a fab project but a few things on the list before it. It needs to be on the passenger side to move away from the exhaust but space is scarce over there.:cool:
It just occurred to me that the world needs a GM relay connector made by keep it clean. It would be water tight, stackable, and wired as needed.
TR
just went back and reread your post. You mention the 89 caddy relays and say you have a source for the plugs. Can you tell us who the source is?:cool:
Are these un wired/assembled plugs?
these look like the 40 amp relay sockets which, in the illustrations I have looked at, appear to have a different pin and pin arrangement than the Bosh 5 pin relay and/or the 30 amp relay socket. is this the case?? The 40amp would be very preferable to the 30s but it is a cool thing to be able to use a bosh relay for a spare.:cool:
I think what you are taking about is a Weather Pack 260 relay,
has 3 pins along one side, then two pins on the other side...
(Configuration C used mostly in the C 280 QC relays)
Read more: http://www.jeep-cj.com/forums/f49/s...ing-harnesses-13311/index2.html#ixzz1ph3JBLUT
you are right, glad I didn't order that.
Any thoughts on a through the firewall connector for switch to relay wiring and of course one circuit for the heater and one for the dash lights and the radios.:cool:
Configuration A isn't used very much, and about all the relays you will find in anything from the early 70's up will be Config. B something.
Config. B anything is a higher power relay,
Most A relays are 20 or 30, while Bs are 30/40, depending on if it's Normally Open (NO) or Normally Closed (NC)
GM got REAL fond of the Config. C with the micro relays for headlights, ect.
Just another way to make things lighter duty...
I'm not looking for 'Lighter Duty'.
Most headlights will only draw about 10 Amps, even the H2/H4 lights,
But if someone connects a couple of off road lights, that jumps up to 20 Amps or more real fast... So I want to be ready for that, and I'm including an off road light option in the harness as 'Standard' since it's so prevalent.
I could go all Config. C with the relays, but that would let an option for an electric fan out.
An electric fan in an off roader with a 20 amp relay is a bad idea.
You can exceed 20 amps at full start up on the motor(s) so starting off with a 20 amp relay is a bad idea.
(ask me how I know that! Yup, burned 20 amp relays in my fan circuit every time it got into water... :( )
So I'll start off with a 40 in the first place, and after 40 amps, the breaker should save your fan motor and relay...
Finding a 5 or 6 pin weather pack connector that will fit though the stock grill holes is a challenge,
I've ordered in a couple of different types, but I might have to go with two each smaller connectors to get them to go though the stock holes.
That means an 'Idiot Proof' connector so they can't be hooked up backwards...
And there is a question of park/turn light wires also...
I think I have that one figured out, but I'll have to put one together to be sure.
An alternative for those of us that like to 'roll our own' I've used Mouser Electronics for even odd OE connectors (the OE male/female connector for the backup lights for instance) and other such, what's more they sell by the each!
connector Automotive Connectors | Mouser
