Shackle replacement for a 2.5" lift?
Tremelune
Hollywoo
'83 CJ7 - 258, T5, D30, AMC 20 Detroit locker, D300
I recently did the BDS 2.5" inch lift on my 81 and put Currie greaseable shackles on. They were pretty pricey though. I don't know if there is a cheap option for shackles and am not sure if I would go with one even if there was. A shackle failure could lead to a very bad day depending on what you were doing when the shackle failed.
I have not heard about needing longer shackles with lift leafs. I was running stock shackles on my 2.5” lift with no issues. When I went to a 4” lift, I did swap out the stock CJ shackles for stock YJ shackles which went from 3” between the bolt centers to 3.5”. Again, no issues. And my YJ shackles do not even have that support piece in the shackles. They are just the two sides. Good luck.
By the way, the spacing between the sides of the shackles look a little too wide and are not snug against the bushings. They should be tighter without any gap. That would definitely add to a poor ride.
Re: Shackle replacement for a 2.5" lift?
Those aren't "janky" shackles by any means. They are actually very nice and strong. You main two issues are the leaf spring alignment and the worn bushings. Replace those bushing, loosen the axle mount u-bolts a bit and tap the springs to be right under the top shackle mount and tight everything back up. I would keep those and for a 2.5 in spring factory length shackles will be fine.
One other thing that needs attention is the passenger side shackle hanger and frame area. That looks like it was bent pretty good and some odd repair might have been done that need to be redone better. I would replace that hanger ASAP.
Well. The shackles may be good, but they're bent 1/2" inward, and the bushings are shot...Are there bushings available for 2.5" shackles designed to accept 2" springs?
I'm gonna take it apart soon and see what's really under that rust area. I suspect I'll need some professional welding help.
I'm trying to avoid convincing myself that the OME YJ conversion is justified...
They are bent because the other owner over tightened them. That can be pulled back straight very easily in a vise. The bushings are factory size and can be bought from any Jeep supplier like Morris Jeep or Quadratec. They will pop right in, pull the shackles straight then bolt them back up and only tighten the lock nut until it is seated. Use new lock nuts and you will be good to go. If you want the OME YJ conversion for ride quality then go for it as that is considered one of the best out there. Then the shackles at least in the front will need to be changed out to fit the wider springs.
I'm not sure I understand. If I put bushings for 2" springs in, I'll have the same problem. If I put bushings for 2.5" springs in, the springs will be able to slide a a half inch back and forth between the raised "lips" of the bushings.
It seems like I'd need bushings with 1/2" more lip to them if I want to keep using these shackles with these springs.
The rear springs currently are 2.5" wide and the front springs are 2" wide. You need a set for both sizes. If you go with the OME conversion then both front and rear will be 2.5" wide.
Waite so I just looked the the picture again. Are the front shackles for a 2.5" wide spring? It is hard to tell but if they are then I see your issue.
Are the springs and the hangers both 2” wide? Id fo, go get new shackles and bushings that are made for a CJ (2” wide) and reassemble. I would not want to have slipping nor would I want to crush the ends of the shackle to move i. Toward the spring and hanger.
If you are on a budget, make your own with thick enough flat stock with holes drilled 3” apart. Use new bolts and locking nuts too.
You don’t need the support bar in the middle, but it does add stiffness. The stock CJ shackles do not have it.
There are two types of bushings available for the CJ, one set for the oem style spring shackles and another set for the aftermarket spring shackles. I would suggest bending those shackles to fit with a set of the aftermarket bushings. Another thing I see from your pictures is that the front spring shackle hangars appear to be bent also. After installing a set of high lift springs it does put more load on the hangars. There is a rivet clearance hole on each of the front hangars, this is a common breaking point for them. There are a few aftermarket spring shackle hangars out there that are a lot stronger than the oem version. Those shackles that you have are the best available in my opinion.
Next up: shackles. The ones I have are beastly. They're proving tricky to bend...I'm gonna try and wrap the arms around the jaws of my vice and see if I can get them to open up.
I bought some new bushings from Currie, and I think I finally understand what's going on: Most aftermarket shackles are wider than stock, and they compensate with thicker "lipped" bushings. For some reason, the previous owner got a hold of these shackles, but elected to use the skinny bushings that came with the Rancho lift instead of sourcing a few bushings to fit the shackles...
I'm gonna try and get these suckers straight, swap in the Currie bushings, and then try and get them snug all around. I've read both 16ftlb (Currie) and 40ftlb (some thread) for the bolts, so I'm not quite sure what to do there. I use threadlock on just about every bolt I fasten.
Progress?
I also noticed that my springs don't seem to line up with where the hanger will go...I'm not sure what to do there, but it looks like I have 1/2" to work with if I loosen the U bolts and reposition them. I've never dealt with a lifted Jeep, so everything is an education.
:notworthy:
Yes. This is progress. If I were you, I would mount the springs loosely on the frame and position the axle under it and see where the springs line up. Then work on the u bolts and perches there. Assuming they line up where they should.
And yes, if you go with that style shackle, you need the bushings with the raised edges.
I would do as Torxhead said. Replace those hangers, they are weak. Mine were not even highly abused and I discovered they were cracked. I replaced them with much stronger ones
I straightened one shackle by putting it in my vice and opening it; banging the vice open with a hammer. When I moved on to the second, something inside my vice gave and now it can't force itself open anymore...I think I'm gonna cut my losses on that front.
Shackle recommendations? My plan was to get a set of Currie suckers, but I would prefer a set that are stock length. I'm not sure a 3/4" different will make much of a difference either way...
In other news, I opened up the bench-seat-storage-box for the first time and discovered a new shackle mount! I guess this was on the previous owners list. Wish I'd opened that up before...I also found a license plate and a Haynes manual. Wild stuff.
The front axle gets positioned by the centering pins on the top of the leaf springs. When you loosen the u-bolts, it will shift around a bit since the clearance hole on the axle spring pad does have quite a bit of clearance on it. You might have an issue lining up the spring shackle to the bushing locations if the leaf springs are twisted up a bit from off road travel, so just force them on. Like if you loosen everything up to install the shackles. You might be able to spread out those spring shackles by using a 6" length of 1/2" all thread and some heavy duty nuts and washers placed on the inside of the shackle. That length of all thread can come in handy also for spreading out driveshaft and front axle ears as they get spread out a bit when the universal joints get broken. Don't overtighten those ears on the shackles either.
Another thing you have to consider about extended length spring shackles is that they will affect castor. Although yours are pretty short.
$150.00
  75.0%
