Six Cylinder Engines
BusaDave9
Always Off-Roading Jeeper
- Durango, Crawlarado
- 1979 Jeep CJ5 with 304 V8, T18 Transmission, Dana 20 Transfer case with TeraLow 3:1 gears, 4.88 axle gears, Detroit Locker up front and Ox Locker in back with 1 piece axle shafts, 36" SuperSwamper SX Tires, Shackle reversal, MileMarker Hydraulic winch, MSD 6A ignition.
“Dauntless” Buick 225
V6 Engine
The Dauntless V6 engine was used in some CJ5's and CJ6's from 1966 to 1971. It is called an “odd fire” V6. It is a 90 degree V6 that is basically a V8 with 2 cylinders removed. Because the crankshaft was not changed to even out the rotation of the cylinders this V6 this engine has a distinctive rumble.
The 225 has 3 main bearings.
Bore – 3.75 inches
Stroke – 3.4 inches
Compression – 9:1
Horsepower - 160
Information for this post was obtained from Novak's web site
V6 Engine
Bore – 3.75 inches
Stroke – 3.4 inches
Compression – 9:1
Horsepower - 160
