Slave Cylinder rod wont return.
c80cj7
- Martinsburg,WV
- 1980 CJ7 258ci, T5, Mickey Thompson rims/<-BAD WORD-> Cepek tires.
Slave cylinder would leak out all the fluid, decided to replace. Bled system, however, when I engage the clutch, the slave pushes out the rod...when I disengage the clutch, the rod stays...I push the clutch again, rod goes out further, after about 10 clutch pushes, the rod pushes completely out of the slave cylinder, and the fluid dumps.
I put back together the rod/slave etc, rebled, tried again. Same results.
Researched it, some say Master cylinder piston is stuck. Any ideas? Thanks in advance.
