Template errors
  • Template public:post_macros: [E_USER_WARNING] Method isPortaArticle is not callable on the given object (XF\Entity\Thread) (src/XF/Template/Templater.php:1278)
  • Template :: [E_USER_WARNING] Method canViewMedia is not callable on the given object (XF\Entity\User) (src/XF/Template/Templater.php:1278)
  • Template :: [E_USER_WARNING] Method canViewResources is not callable on the given object (XF\Entity\User) (src/XF/Template/Templater.php:1278)
sm465 shift lever
dinuba, california
share my son's 80 cj7 jeep sr4 trans 151 cu inch 4 cylinder it has a 4 in lift with 2 in body lift with 35in procomp tires on 10 in wheels.
i would like to know how to install a shift lever on sm465 trans. i to see some pictures if possible, of parts that go under the boot and bottom of lever thanks
Look down inside the tranny tower and make sure the three different rails are lined up so there is a straight rectangular slot for the shift lever to slip down into.
slide the stick straight down into the slot and push the ring down and turn to engage the tangs on the side of the tower.
Didn't notice the date.
