Small block conversion.
Vikingone
Lake Worth FL
85' CJ7, 4.2 Liter, swapped in T18
So I’m seriously contemplating doing a small block 350 conversion. Over a reman 6 cylinder. I know about needing a bell housing adapter and a larger radiator. What about the power steering system?
Novak is a great site lots of good info on the sbc swap. Yes you can use your ps pump, just have get new brackets and maybe a pulley depending on the brackets used. Both the pump and box are basically GM. If you do decide to do the swap look up bomb proof motor mounts from More offroad. The best mounts IMHO.
I have a complete front accessory kit, radiator, shroud, and engine mounts. I have two 350’s and a few other things. I will be putting these items on CL. You can PM me if you’d be interested in any of these items to keep your thread in line with the topic. I know TX and FL are $$$ apart. ☹️
