Smog Pump Pulley
Smog Pump Pulley
MadCJ95
Denver, CO
1995 XJ; trail rider
1980 Cj5; 258/T5/D300 with stock axles (4.10s for now) and 235/75 tires.
Wrong belts numbers in the book is a common thing in my experience. Take a cord and wrap it around the pulleys, mark it then measure. (Do it both with the adjustment completely in and completely out.) The parts house will have something in stock that is close; give it a try.
Does the belt only run between the fan pulley and the smog pump? or does it go around the harmonic balancer as well?
Thanks! :notworthy:
that is the right pulley and it goes around all three.:cool:
After 5 runs to the parts store and a long piece of string, I got it! The outer diameter of the belt needed it 53", while the inner diameter is ~50".
Thanks for all the help! :chug:
