Soft Brake Pedal.
csuengr
- Loveland, CO
- 1980 CJ-7 LT1 TF727 NP231-D300 Waggy D44's ARB's 35" tires
I have had this issue with my 1980 CJ7 since I rebuilt it six years ago. I can push the pedal to the floor. Tires will only lock on dirt, but only the fronts. Parking brake works fine.
Basic parts:
Waggy front and rear axle and brakes with Waggy master cylinder.
95' YJ booster.
I have bled and bled the brakes and no change. Even pulling the thingy out on the proportioning valve while bleeding. The booster push rod is adjusted properly. I know this because if I extend the length any, the brakes drag. No play in the brake pedal. I am wondering now about the pedal ratio and if its not working with my master cylinder.
Basic parts:
95' YJ booster.
