Softer Ride
Maybe thats the reason why they don't make them anymore.Jeep CJ's weren't built for a 'soft-ride'.
Hi, I want to know if the kyb gas-a-just or procomp mx6 are good shocks? good for more stability and softer ride? thanks
Get the softest/wimpiest non-gas shocks you can find.
Those 2 you list'd, will beat you to death-
and make sure your shackle bolts are not higher then 20-22 ft lbs. I set my over the road tire pressure at 20 psi.You could also get some help by using a bit less on the tire air pressure also.
They do all seem to bounce down the road ...the jeeps, not the lawyers.
I kinda feel like a bull rider sometimes when I notice I'm leaning forward or back as I move into a bump. I'm pretty sure I don't do that in my Honda Civic lol.
What type/condition tire you have matters as well. I was running 31 10.5 Dueler AT's at 26ish pds and when I switched over to a BF Goodrich AT that was wider the ride is less harsh...and I'm running them at 35 pds. So it really all kinda goes together. All things being equal though, the wrangler springs are going to be a way smoother ride than the stock springs.
After reading this post, I'm about to go buy some of those cheapo shocks since the PO had some Rancho's that are still on there. Maybe I can make it even a little less jarring and stay of the bull for the full 10 seconds
