Speedometer Cable Drive Gear
Rainman6412
Hi,
Just purchased a 1966 Jeep CJ5 , with the 225 V-6 engine, that had been sitting up for about 15 years and as you can imagine it needs a lot of tender loving care. I replaced all the worn out steering linkage, changed all the fluids, new carburetor, put in a new wiring harness and replace most of the lights, and now I have it where I can at least drive it a round.
I need your help in locating a speedometer cable drive gear that goes into the Transfer Case . On my Transfer Case the drive gears screws into the Transfer Case , it doesn't have a plate holding it in like some of the others I've seen. Someone before me had remove the gear and replaced it with a plug. I have attached a picture showing the markings on my Transfer Case and also the plug where the speedometer drive cable gear should go, I think. Thanks for any help and guidance you can give me.
Doug
Doug
