Build Thread Starting my build
thunderlizard66
I bought this jeep the other day. Someone had already done a 4.0 swap. The PO that I got it from bought it in May14 and didn't know much about it except that it drove until December and then due to a fuel issue it stopped running.
I looked it over quick, the frame had been repaired, the body has some rust but it also has been patched in the past.
Well I looked this am and came up with some issues.
1. If your using a renix motor do you still need the CPS. Because it's not on the bell housing or the harmonic balancer!
2. I can't find then VSS, the speedo is still a stock CJ going into the transfer.
3. They did mount an electric fuel pump and inline filter on the frame. Does anyone know what the pressure should be?
4. Believe it or not there is not a fan mechanical or electric! Thank god it's cold up here.
Thanks in advance
Thanks in advance
