Steering box: Custom Support
JR74CJ5
Missing-Presumed Wheeling
Lifetime Supporter
Plumas Lake, CA, USA
1974 CJ5 ~ Fresh built AMC 360 - SM420 - D20 - D30F with upgraded 30 spline shafts and knuckles & D44R - 4.27 Gears - ARB Lockers F/R - All chrome molly axles - on 33's - YJ 4" Lift Spring Conversion
I might have to get one of those, pretty fancy for the money.
I have one that is really cheap looking next to that, it's been doing ok so far. But I like the one you found.:chug:
Yeah I think I will need to get it... :drool:
I'll let you know how it installs (Easy or PITA):cool:
~ JR
I have one on my cherokee and love it
got a 1979 CJ5 with brken steering mount bolt on the underside of the frame. Got any ideas how to get them out or ?? Think i can grind them flat and weld on studs ? The guy who had it before welded the winch mount across the openings in the frame so i cant get into the frame to drop in new bolts. any suggestions ?
Post a picture up... We'll check it out :cool:
Use a hole saw to access the steering box bolts. Use grade 8 bolts. don't be welding studs on. :)
What he said
