steering column - missing cover?
jjump
Pittsburgh
CJ7
Hello all,
After replacing my cylinder lock because the key falls out when running, I notice that I am left with a gap between the column and the wheel.
No big deal, anyone know of a cover to fix this?
THX
I believe my CJ (with what assume is a factory steering wheel) has a rubber like cover on the back of the steering wheel. Or it maybe actually be a spacer between the column and the wheel, it's been a long time since I pulled the steering wheel off.
I would check aftermarket steering wheel manufactures and see if they some type of spacer. For reference, the CJ column is the same Saginaw column the GM used in cars for quite a while (60s-80s I believe).
