Steering Stabilizer
Steering Stabilizer
Vick68
South Carolina
1973 Cj5 71 AMC 360 4 spd Manual Front & Rear lockers,
1999 F250 extended cab 5spd Triton V10
What do I have to do to add a steering stabilizer? I have a 73 CJ5 . I have 33 in. tires and no idea how much lift but it is lifted. It needs better handling so I'm going to replace the steering box and would like to add a stabilizer.
I bought a Rancho one and it came with everything you need to mount it.
:)First off don't think the addition of a steering stabilzer is going to be a cure all.................CJ's are will known for there I'll handling brought on by a lift package,bump steering, larger tires, shackles, ball joints, Tie Rod ends, Etc; or just worn out components both front and rear.
You need to spend some time looking and here is a good place to start,.................http://www.jeep-cj.com/forums/f99/troubleshooting-correcting-your-steering-4106/
:D:D:D:D
X2!!!
mine came with a rancho kit, the op removed to do a tie rod and for the life of me can't get it installed w/o hitting the diff!! i have been fine with out it...4" w/ 33s do a bit of highway driving also!
