Stuck master cylinder
Colo Dean
- Greeley Co
- 74 CJ5 258 I-6, 4 spd T-18, Dana 20 T/C, Dana 30 Front, Dana 44 Rear 4.27:1, still learning everything about this one, 14 JK pretty much stock
As the title says, I am trying to remove the master cylinder from the firewall on my '74 CJ5 . Removed the two nuts holding it to the firewall and the rod that connects to the brake pedal is firmly attached. Every master cylinder I have seen the rod is separate. It it just maybe stuck or rusted to it or is the rod part of it? Tried to turn it a small amount and it doesn't seem to budge. Don't want to break anything. Brakes are drum/drum if that makes any difference. Appreciate any help getting this off.
Thanks!
Thanks!
