Engine Suspected carb issue
I'm having an issue with starting my 85 CJ7 , AMC 258 i6 / 4.2l with Carter carb. For the first start after sitting for a day or longer, the engine turns over for a long time. Once it catches, it runs fine and will start immediately the next time I turn the key for the rest of the day. I don't drive it every day and the longer it sits, the longer it takes to start. I don't know much about carbs but I'm guessing it has to do with fuel, or lack of fuel, in the bowl on that initial start. Is that a possible answer and if so, what do I do about it? One of the POs striped a lot of stuff connected to the carb as you can see from some of the attached pics. But once it starts, it runs pretty well. Any suggestions?
