Swapping SR4 to T176 shopping list
smbundy13
- Texas
- 1980 CJ7, 258 I6, SR4, D300. Power steering, power brakes. Stock axles stock susp. Gentle rehab in progress.
My clutch in my ‘80 CJ7 has started to slip pretty bad in 3rd and 4th when putting load on the engine, ie going uphill.
So, I am thinking it is time to replace with new clutch and whatnot. I am also bartering with my neighbor for a T-176 out of a j truck with the AMC 258 i6 / 4.2l since he is swapping in a 360.
I know I will need new driveshafts for sure and, obviously, a new clutch, throw out bearing, flywheel and maybe pressure plate.
Is there anything else I need to look at replacing? I will just buy a new tunnel cover from Novak and drill new holes for the shifter.
I will also probably replace the mount bushings for motor mounts and Transmission mounts since when I’m idling at a stop light my Jeep feels like an old Harley.
Any recommendations for clutch? I don’t wheel much and when I do it’s not hard wheeling.
Thanks a lot.
Thanks a lot.
