Sway bar quick disconnects purchase
81CJ7WY
Mountain West
81 CJ7, 258, t176, D30, AMC20, 4.56
Good morning all, next project quick disconnects. I'm wondering what brand others have, What you like about them and what you don't . I have a 4 inch rough country, and 33 inch tires on a 81CJ7. Thanks.
Years ago my buddy bought a 4" lift for his YJ and it didn't have all the stuff he needed so we had to hit Collins bros since I live a few miles away and we got the skyjacker disconnects because that's what they stocked, however I was impressed with their firmest and machine work you would not have any rattling out of them
https://www.jeep-cj.com/reviews/suspension-steering-2/
JKS greasable,no rattles.Easy to use.
TrailQuest:
TrailQuest is still around, but no long makes 'stuff'.
Been on for a lot of years, I've never disconnected them, but if I ever get around to I'll put some anti-seize on them.
Thanks for the input and pics
Here is my 307 solution to quick D's. Drilled each bolt, upper and lwr, for a pin and installed the Jks style pins last night. Takes about 15 seconds each to disconnect. I keep the post well lubed, will drill and tap it for zerks eventually.
I used old shock eye's cut off with their original bushings, 3/8" all thread and grade 8 shoulder bolts, cut off wheel, and a welder and made my own...
what they wanted for some of those was crazy ($) - mine have been working well for a while now, we'll see if I spring for some good ones later... :D
You might want to try driving on the street with those sway bars disconnected to see just how much it really does help. A lot of guys just throw the sway bar away when a lift kit is installed. I think they do help in the corners a little but not that much.
Thanks to all for the replys. removed my improvised sway bar connectors and while the RC is stiffer than I would like, it has better manners on the road with them connected. Never seen a vehicle complain so much while on pavement. Off road, it seems very happy disconnected.
I didn't throw mine away.....
Makes a nice handle for my home made brake. :)
4 days, 10 hours, 8 minutes, 20 seconds
