T-150 Upgrade?
BajaEdition
Resident 'Old' Jeep Shaman
- Featured
- 2
- Media
- 136
- Resources
- 2
- Riverside Ca
- 67 cj5,225 Dauntless, D30,chrome molies, detroit, D44, full floating detroit, custom steering, disc all the way around,2 inch lift on 31s, armored up
70 cj6 4 inch lift
The D 18 and Dana 20 transfercases are closely related, and the first to use a D 20 case with D 18 parts was Jeep, It is called a Super 18 as the case is stronger. If you do want to do this you need to get the gearing for the D 18 with a 1 1/4 intermediate shaft, strongest one they offered. also check on the input shaft spline count. One other place you need to check is if the hole of the input on the D 20 will work, if not they make a smaller adapter for it.
The Warn Overdrive unit you put in the thing will really start you rocking and rolling as it is a 25 % unit, grat for Hwy speeds and like said, effectively gives you double the gears you have multiply that by 2 for the lowrange and you can really get a lot of gear choices however it unit does not work with the LOW LOW gear ranges you can put in a D 18, The unit works in the PTO port so you cannot use it on regular D 20.
And as said, a D 18 has a passenger side offset to the rear output, which can give you a problem if you have a short rear driveshaft
Still need pics ?
Still need pics ?
