    Thank you for your support!
T-176 4 Speed Question....
jjump
Pittsburgh
CJ7
Hello all,
Was talking to the owner of a potential Jeep I am going to look at this weekend, a 1985 CJ7 with the 4 speed T-176 .
The owner states that sometimes the Transmission will stick, and you have to go to reverse then back into first when this happens.
He did state it has never happen while driving, only while going into or out of reverse or from a parked position.
I've read most of the comments on the worn shift forks, and lining up the gears, and the worn shifter, which all seems easily replaced from the top of the Transmission .
Is there anything else that I should be concerned of? The Novak guide seems to have the rebuilds of these straight forward.
Others will have more info then me on this, but I have rebuilt the top end of several T-176 and there very simple. In my cases that was the reason for the top end rebuild was to fix the "sticking" situation.
Sounds like a worn 'drive' gear.
Take it for a drive after you confirm oil level.
Hands on is the best-
