T-5 Synchro's Question
marculan
- Berlin, CT
- 85 CJ7 258, 68 Camaro RS 327, 65 ERA FIA Cobra Replica, 93 Spec Miata
I’m rebuilding a T-5 from an 85 CJ and I’m not sure if my rebuild kit came with the right parts. Of the 6 synchro’s in the kit, 2 are smaller diameter and clearly for 5th gear. I think I only need 1 here, but the kit came with 2. Of the other 4 rings, they are all the right diameter for 1/2 and 3/4 but one of them is a tenth of an inch or so thinner than the others.
I can't figure out how to post a picture, but imagine one ring that doesn't cover the entire tapered part of the gear, while the other rings cover the entire tapered part.
Is this correct, to have one ring that is thinner than the others, or did I just get the wrong part? If it is supposed to be this way, which gear would it be used on?
Thanks,
Marc
Thanks,
Marc
