T-5 to T176 swap
T-5 to T176 swap
bdpalace
KY
1983 CJ7 Laredo, 4.3L Vortec, T5, Dana 300, 1 piece posi rear axle
Can you switch out a T-5 with a T-176 without a new bellhousing? I read the bolt pattern on a T-5 (butterfly) only matches 3 of the 4 bolts on the T-176 , but have also seen posts about switching a T-4 (same bolt pattern as the T-5 ) with a T-176 . So what's the real deal?
I currently have a T-5 mated to an unknown bellhousing that is connected to a Chevy 4.3L and have been offered a a T-176 for next to nothing. If it will bolt straight up, then it's a no-brainer...I'll snatch up the T-176 . If not, I've gotta decide if I want a huge paperweight sitting around the garage until I swap it in.
I currently don't have any issues with the T-5 , but have read that they are prone to issues and will eventually fail. If I get the T-176 as a back-up, I just want to know what additional costs I'll be looking at to install the T-176 .
Thanks for the help!
Figured I'd try here before staring my own tread. Just picked up a T-176 and had a few question.i did get it bell to adapter and got some shafts in the works. What else do I need? Like the reverse switch? I got a twin stick so what boot? Just look for some who's done the swap for some info. Thanks..hope to tackle the install soon
And is the stick usually very wobbly on these???
