    Thank you for your support!
t150 to t176
t150 to t176
79Jeep5
marysville ohio
1979 CJ5, 2000 Jeep TJ
Im trying to swap my T-150 to a T-176 . I have the tranny mounted to the bell housing but now I cant get the skid plate to bolt up to the frame or the stabilizer arm.
Which skid plate are you using? is there a difference between the T-150 skid and the one from the T-176 ?
I have both skid plates and they are both different. The only thing I dont have from the T-176 is the stabilizer arm and mount but I think those are the same.
will the Transmission mount bolt to the skid plate before you bolt to the frame?? If so how far off are the frame to skid plate holes??:cool:
