T5 from a Camaro
T5 from a Camaro
jwill22
El Paso
1984 Cj-7, rebuilt 258i, Carb-Motorcraft 2150, TFI ignition, T-176, Dana 300, dana 30 in front, Rear Dana 44, 4in lift, 33in tires, 4:10 gears
Not sure if this is a dumb question: but what's the difference between a T-5 that was used in Camaro to that of one in a jeep?
I'm still looking for a Transmission and i stumbled across a post on craigslist. It's a T-5 and even though im looking to upgrade i also need to get the jeep going since i need a daily driver once again. Plus its hard to find any transmissions out here in el paso for a decent price. Supply and demand i guess.
anyway here is the post i found on craigslist, it has a picture of the stamp I.D
T5 transmission / 5 Spd
Thanks for the help!
World class T-5 's were used in Mustangs and Cameros. They are not interchangable with Jeep T-5 's. You MIGHT be able to do it, but I'm guessing since I've never seen anyone do it in 20 years of Jeeping that it's not cost effective to do it (by the time you swap out everything that needs to be swapped, your in $$$$, whereas you could swap a different Transmission in (AX15 for example) and be $$$ ahead.)
The Borg-Warner T4 & T5 Jeep Transmissions - Novak Conversions
Mustang T5 vs. Jeep T5 - JeepsUnlimited.com Forums
It's not worth it.
The shift on a 2WD T-5 is in the tailhousing. On the 4WD version that shift is in the rear TCase mount. It is possible to convert a 2WD to a 4WD T-5 but it's far from worth it. The T-5 is among the worst transmissions to ever go into a CJ.
T-5 -5speeds-com.jpg" data-src="/community/proxy.php?image=http%3A%2F%2Fwww.jeep-cj.com%2Fgallery%2Ffiles%2F1%2F6%2F7%2F1%2Ft5-5speeds-com.jpg&hash=c73652d3e68fe091a88d04c06d60b995" data-lb-sidebar-href="" data-lb-caption-extra-html="" data-single-image="1"> t5-5speeds-com.jpg
http://www.jeep-cj.com/forums/f105/manual-cj-transmissions-12112/#post97094
Thanks for the heads up! Luckily i didn't make an irrational decision and go out there and buy it on impulse, then id be really screwed.:eek:
