T5 noise
b3uhbp
- Arlington, TX
- 84 CJ7, 258, T5, Dana 300, Dana 30' AMC 20' Weber 32/36 carb, DUI HEI ignition, 2.5" suspension lift
Trailing thought....
If you end up pulling it, and plan on taking it offroad much, do consider an AX15 swap.
I finally got sick of my T-5 .
Smashed itself under normal conditions at low speed.
The AX15 swap makes the Jeep drivable in any condition. Highway to trail.
Sent from my Pixel 2 using Tapatalk
You SURE the noise is not from the Transfer Case ?
Gary
What tire size and R&P ratio were you run'n?
Have run a T-5 since I bought my Jeep in 1985.
I run 33's and 4:88 gears w/DL's ft & re.
Gary
Wouldn't say easy.I had thought about that in the past. Is it an easy swap/direct bolt up?
