Tachometer
Tachometer
kenpoman2003
Whitefield, Me
1986 cj7 4" suspension lift, 2" body left. am going to install rear bumper tire carrier, front bumper brush and grill guard, front roll cage and tie in kits. all as money becomes available. dana 30 front end with quadraqtrac four wheel differential. amc 20 locking differentail in the rear. Have solid piece axels just waiting to be installed some slow winters day hopefully in heated garage. Am also going to do, do it yourself paint in tub liner havent decided which one to go with. Any sugestions? hope to do this to the underbody and frame as money allows. I have ordered marine interrior lights for under dash and bach passenger compartment and under hood w/ heavy duty toggle switches. I plan to install a secondary fuse block to acommidate any accessories I may someday get. I know it sounds like a lot but its a pick away project with no deadline. and as money provides.
Do I need a special connector to attach a tach wire to a high performance DUI distributor or can I use a common connector? If so what kind? thanks for any help
You will need something like this:
Hot Rod Wires automotive terminals connectors quick disconnect fusible link
bought one and it worked great thanks everyone fir your input
$20.00
  10.0%
