Misc Gas tank cj7
Misc Gas tank cj7
Starbrick Jim
Spring Hill KS
83 CJ7, 42 MB
I have a 1983 CJ7 Renegade and it has a disfigured rectangular gas tank skid plate/box which a poly tank fits into. The skid box is in rough shape and I want to replace it. The tank skids available do not resemble mine so I am not sure what to do. I could purchase a new tank and hopefully the available skid plates will work with it. While looking at the tanks, I see that filler is on the passenger side as well as the sending unit whereas the new tanks have the sending unit on the drivers side. Does anyone have some thoughts or direction that I should follow? Thank you very much.
How bad is your tank box? They can be repaired/bent back to shape when disfigured. Ask me how I know😏
My guess is that aftermarket stuff will not fit as well. Maybe someone else has another idea though.
Hate to say this but since you have a poly tank that is far from factory.
They are not bad at all but require things.
Poly larger tanks limit ground clearance and removal of the skid plate.
If you're not doing off-road that needs a skid plate you are probably ok.
Can you supply pictures?
CJ. Later CJs indeed had plastic tanks from the factory. Somewhere around ‘82 they showed up.
Yes my 84 came plastic. 15 gallon. Think I’m on my 2nd metal. First was a 22 gallon metal tank. To big. I really like the 15 gallons I bought from Holley. Sure they don’t make it but good quality and was a reasonable price. The plastic also warp with age.
Yikes! That rust is bad.
You mentioned a new frame too. I guess the box isn’t your biggest problem?
$45.00
  22.5%
