Tail lights / Brake Lights
Eric
L.I. NY
1980 CJ5
ripped out old wiring and running new behind dash adn to lights. the brake lights and rear bilnkers work but when i turn on the light the rear lights do not turn on.....only when i step on the brakes. I cannot figure it out...any suggestions??
Did you check the bulbs? They are two filament, one for brake/ turn signal the other for tail lights. Check the bulb socket, too.
I would also recheck wiring for correct hookup and double check connections at the light switch. If you have one wire hooked to the wrong color that can mess things up.
$35.00
  17.5%
